Surface finishes
Aluminum anodizing services
We offer anodizing type II and III, which are ideal surface finishes for aluminum parts. Anodizing strengthens aluminum parts and is available in several colors, depending on the type. All types of anodizing will increase the lead time and cost per part.
Anodizing type II
Surface preparationColorsGlossinessCosmetic availabilityThickness**Visual appearance
As machined (Ra 3.2μm / Ra 126μin)Clear, Black, Red, Blue, Orange, GoldGlossy (Above 20 GU)Nofor clear: minimum average thickness 10μm, minimum local thickness 8μm;black and color: minimum average thickness 15μm, minimum local thickness 12μmParts are anodized directly after machining. Machining marks will be visible.
Bead blastedClear, Black, Red, Blue, Orange, GoldMatte (Below 10 GU)Cosmetic on requestSame as aboveGrainy texture, matte finish
Bead blastedClear, Black, Red, Blue, Orange, GoldGlossy (Above 20 GU)Cosmetic on requestSame as aboveGrainy texture, glossy finish
Brushing(Ra 1.2μm / Ra 47μin)Clear, Black, Red, Blue, Orange, GoldGlossy (Above 20 GU)Cosmetic on requestSame as aboveParts are manually brushed to reduce marks, then anodized. Brushing lines will be visible.\
Tolerances for all surface preparations are held after anodizing
Anodizing type III
Surface preparationColorsCosmetic availabilityThicknessVisual appearance
As machined (Ra 3.2μm / Ra 126μin)Black, Natural (thicker layers will appear darker)No35 to 50μm(0.0013” to 0.0019”)Parts are anodized directly after machining. Machining marks will be visible.
Bead blasted (Glass beads #120)Black, Natural (thicker layers will appear darker)Cosmetic on request35 to 50μm(0.0013” to 0.0019”)Can be slightly visible if parts are “Not Cosmetic” Completely removed if parts are “Cosmetic”
Non standard requests
* We supply a range of standard colors (see color options). If you need a particular RAL or Pantone color code, please contact networksales@protolabs.com
**As a standard, our anodizing thickness will follow ISO 7599: ISO class AA10 (for clear) and ISO class AA15. If your parts require different standards, please contact networksales@protolabs.com
Color options for aluminum anodizing type II
Color anodizing can have some variation in color due to standard alloy tolerance variations. Check the color scheme below to see the color range.
Black (Black MLW)
Similar to: RAL 9004, Pantone Black 6
Clear
Similar to: depends on material
Sample part showcasing red anodizing
Red (Red ML)
Similar to: RAL 3031, Pantone 1805
Sample part showcasing blue anodizing
Blue (Blue 2LW)
Similar to: RAL 5015, Pantone 3015
Sample part showcasing orange anodizing
Orange (Orange RL)
Similar to: RAL 1037, Pantone 715
Sample part showcasing gold anodizing
Gold (Gold 4N)
Similar to: RAL 1012, Pantone 612
Color options for aluminum anodizing type III
Sample part showcasing aluminum anodizing type III in black color
Black
Sample part showcasing aluminum anodizing type III in natural color
Natural
Example of an anodized part
Bead blasted + Anodized type II (Matte)
As machined (Ra 3.2μm)
Design considerations for aluminum anodizing
  • Anodizing involves suspending parts via a “jig” or “rack.” This will leave marks on your part where anodizing wasn’t possible. If there are areas on which you can’t accept “jig” marks, please remember to include a technical drawing indicating these areas and follow our cosmetic procedure. Learn more about this on our surface finishing page
  • Anodizing insulates your parts, reducing their conductivity.
  • Masking is not required by default, as type II anodizing doesn’t raise the thickness of your part significantly. Remember to indicate in your CAD file whether you want specific part areas to be masked or plugged.
  • Type III anodizing, however, adds substantial thickness to your part’s surface. We apply masking by default to protect threads and engineering fits. To have these features anodized without masking, please specify this when placing your order.
Our anodizing process
Anodizing is an electrolytic process both for protecting aluminum parts against wear and corrosion and for improving cosmetic appearances. Let’s break down the basic steps for anodizing a part:
  • Connect the part to an anode
  • Submerge the part in acidic electrolyte solution
  • Apply a cathode to a metal electrode in the solution
  • Positive ions react with negative O2 ions and the surface becomes porous
  • This grows a layer of aluminum oxide on the part
  • Use corrosion inhibitors or colored dyes for cosmetic purposes
  • Seal the nanopores
Read more about anodizing
Aluminum anodizing video resources
When to (not) Use Anodizing for Your Parts
Anodizing - What is it and How Does it Work? Complete Aluminium Anodizing Process Explained
Put your anodized parts into production today
