Online CNC machining service
On-demand CNC machining service for rapid prototyping and production parts, through a network of specialized, experienced and thoroughly vetted local and global CNC machine shops.
Get instant CNC machining quote All uploads are secure and confidential
Our CNC machining service capabilities
CNC machine all types of parts, from simple “as machined” workholdings to complex geometries. Our manufacturers operate almost every kind of CNC mill and turning center, with EDM and grinders available on request. We offer tolerances down to ±.020 mm (±.001 in) and lead times from 5 business days.
3 & 5 axis CNC milling CNC machined part, CNC milling, anodized surface finish
Access over 1,000 milling centers, including standard 3-axis mills, indexed 3+2-axis mills & fully-continuous 5-axis mills
Access over 300 turning centers, including Swiss lathes and multi-axis mill turns.
Phosphor Bronze PB102
Mild steel
Mild steel
Brass
Brass
Copper
Copper
Alloy steel
Alloy steel
Tool steel
Tool steel
Inconel
Inconel
Magnesium
Magnesium
Invar 36
Invar 36
Phosphor Bronze PB102 | 2.102 | CuSn5.
Alloys
Alloys
Aluminum 6061-T6511 | 3.3211 | 65028 | AlMg1SiCu Aluminum 7075-T7351 | 3.4365 | 76528 | AlZn5.5MgCu Aluminum 6061-T651 | 3.3211 | 65028 | AlMg1SiCu Aluminum 6061-T651 | 3.3211 | 65028 | AlMg1SiCu Aluminum 7075-T7351 | 3.4365 | 76528 | AlZn5.5MgCu Aluminum 7075-T651 | 3.4365 | 76528 | AlZn5.5MgCu Aluminum 6082-T651 | 3.2315 | 64430 | AlSi1MgMn Aluminum 6061-T651 UT / Certified Mill Reports Aluminum 7075-T651 Aluminum 6082-T651 Aluminum 6061-T651 UT Aluminum 6061-T651 UT Aluminum 6060 | 3.3206 | AlMgSi Aluminum 5052 | EN AW-5052 | 3.3523 | AlMg2,5 Aluminum 2017A | 3.1325 | 24530 | AlCu4MgSi Aluminum 2014 | 3.1255 | 24345 | AlCu4SiMg Aluminum 6063 | EN AW-6063 | 62400| AlMg0,7Si Aluminum 7050 | EN AW-7050 | 3.4144| AlZn6CuMgZr Aluminum MIC6 Aluminum 2024-T351 | 3.1355 | 24530 | AlCu4Mg1 Aluminum 7075-T6 | 3.4365 | 76528 | AlZn5,5MgCu Aluminum 5083-H111 | 3.3547 | 54300| AlMg4.5Mn0.7 Aluminum 6082 | 3.2315 | 64430| AlSi1MgMn Aluminum 6061-T6 | 3.3211| 65028| AlMg1SiCu Show all alloys
Alloys
Stainless steel 15-5-H900 | 1.4545 | X5CrNiCu15-5 Stainless steel 15-5-H1150 | 1.4545 | X5CrNiCu15-5 Stainless steel 17-4 PH-H900 | 1.4542 | X5CrNiCuNb16-4 Stainless steel 17-4 PH-H1150 | 1.4542 | X5CrNiCuNb16-4 Stainless steel 416 | 1.4005 | X12CrS13 Stainless steel 15-5 | 1.4545 | X5CrNiCu15-5 Stainless steel 440C | 1.4125 | X105CrMo17 Stainless steel 430 | 1.4016 | X6Cr17 Stainless steel 301 | 1.4310 | X10CrNi18-8 Stainless steel 420 | 1.4028 | X30Cr13 Stainless steel 304/304L | 1.4301/1.4307 | X5CrNi18-10/X2CrNi18-9 Stainless steel 2205 Duplex | 1.4462 | 2205 | X2CrNiMoN 22-5-3 Stainless Steel 17-4 PH | 1.4542 | X5CrNiCuNb16-4 - Annealed state Stainless steel 303 | 1.4305 | X8CrNiS18-9 Stainless steel 316/316L | 1.4401/1.4404 | X5CrNiMo17-12-2/X2CrNiMo17-12-2 Show all alloys
Mild steel
Alloys
Mild steel S275JR | 1.0044 | Fe430B | IS2062 Mild steel S275JR | 1.0044 | Fe Mild steel S355J2 | 1.0577 | 1522H | Fe 510 D Carbon steel C45 | 1.0503 | 1045 | EN8 Mild Steel S235JR | 1.0038 | Fe 360 B Mild steel 1045 | 1.0503 | C45 | EN8 Mild steel A36 | 1.025 | Fe 410 Mild steel 1018 | 1.1147 | C18 |16Mn Show all alloys
Brass
Alloys
Brass 260 (70/30) Brass Cz121 | C38500 | 2.0401 | CuZn39Pb3 Brass Cz121 | C360 | 2.0401 | CuZn36Pb3 Brass (billet) Cz112 | C464 | 2.0321 | CuZn36Sn1 Brass Cz112 (60/40) Brass C360 | 2.0375 | CuZn36Pb3 | 319 grade 2 Show all alloys
Copper
Alloys
Copper CZ112 Copper CZ112 Copper C101 | CU OFE Copper C110 | CU ETP
Alloy steel
Alloys
Alloy steel 1.7131 | 16MnCr5 Alloy steel 1.7225 | 42CrMo4 Alloy steel 1215 | EN1A | 1.0715 Alloy steel 4340 | 1.6511 | 36CrNiMo4 | EN24 Alloy steel 4140 | 1.7225 | EN19 | 42CrMo4 Show all alloys
Tool steel
Alloys
Tool steel H13 | 1.2344 | X40CrMoV5-1 - Annealed state Tool steel A3 - Annealed state Tool steel S7 | 1.2355 | 50CrMoV13-15 - Annealed state Tool steel O1 | 1.2510 | 100MnCrW4 - Annealed state Tool steel A2 | 1.2363 | X100CrMoV5-1- Annealed state Tool steel D2 | 1.2379 | X153CrMoV12-1 - Annealed state Show all alloys
Alloys
Titanium Grade 5 | 3.7164 | Ti6Al4V Titanium Grade 5 Titanium Grade 2 | 3.7035 Titanium Grade 1 | 3.7025
Inconel
Alloys
Magnesium
Magnesium is the lightest structural metal with high strength to weight ratio.
Alloys
Magnesium AZ31B
Invar 36
Alloys
Invar 36
Nylon
Nylon
PPSU
PPSU
PSU
PSU
PBT
PBT
Polycarbonate
Polycarbonate
CPVC
CPVC
Polyethylene
Polyethylene
LDPE
LDPE
PVC
PVC
PPE/PS
PPE/PS
PS
PS
Polypropylene
Polypropylene
G-10
G-10
PEI
PEI
Nylon
PPSU
Polycarbonate
CPVC
CPVC displays excellent corrosion resistance at elevated temperatures and is ideally suited for self-supporting constructions where high temperatures are a concern.
Polyethylene
LDPE
LDPE's flexibility, toughness, and corrosion resistance combined with its low-cost, high-efficiency production process make it an appealing choice for engineering applications
PVC
PPE/PS
PPE also have low moisture absorption and excellent hydrolysis resistance and can be made flame retardant. Common applications for PPE include components in printers and copiers, electrical devices like connectors and circuit breakers and in vending machines and water softeners.
Polypropylene
G-10
PEI
As machined surface finish
Fine machining surface finish
polishing
Brushed surface finish
Powder coated surface finish
Black oxide surface finish
Brushed + Electropolished
Specialist industries
We’ve manufactured millions of parts for all sorts of applications, but we’re especially knowledgeable in these areas.
Aerospace & aviation
Aerodynamic parts for aircraft, drones, satellites and rockets with AS 9100 certification.
Read more
Medical Image representing medical industry
Medical
Create custom medical devices and diagnostic equipment to get healthcare innovations into hospitals and homes.
Read more
Automotive
Automotive
Fast-tracked development for electric vehicles and other automotive innovations.
Read more
Robotics & automation Image representing robotics industry
Produce complex robotic systems, end effectors and automated machinery for this innovative industry.
Read more
Hone Shaving: Manufacturing High-quality Shaving Products
Watch how the founder of Hone Shaving, Andrew Mitchell, tells the story of how he created his unique and high-quality razors with the help of Protolabs Network.
Watch it here
Get complete program management from our team of experts to optimize cost, quantity, and quality control of production orders for end-use parts. Find out about manufacturing higher volumes at reduced part costs, our commitment to quality and expanded capabilities to support with scaling to production.
Explore production
How Hubs compares
We use automation to make custom machining easier, faster and more affordable than traditional machine shops:
  • We have an incredibly broad range of capabilities - much more than most individual shops.
  • Our quotes are generated instantly - request as many quotes as you like without feeling guilty.
  • No limits on order size - we can scale with you from one-off prototypes to millions of production parts.
  • We leverage market forces within our network to guarantee competitive pricing on every order.
We machine rapid prototypes and low-volume production orders for customers in multiple industries: aerospace, automotive, defense, electronics, hardware startups, industrial automation, machinery, manufacturing, medical devices, oil & gas and robotics.
CNC 101 - hero image 3
When it comes to custom part production, choosing between 3D printing and CNC machining can be challenging. This guide breaks down the key differences between these popular manufacturing technologies, helping you decide which is best suited for prototyping, low-volume production, or functional end-use parts.
  • 25+ plastics & 35+ colors
  • Lead times from 5 business days
Need corrosion protection without adding bulk? Request a free, instant quote and upload your CAD for real‑time pricing on your CNC part.
