SLA 3D printing service
Source high-performing parts for rapid prototyping and production with Protolabs Network's SLA 3D printing service. We offer tons of prototyping and industrial resin materials and can print parts in as little as 1 day.
Get instant SLA quote
What is SLA 3D printing?
Stereolithography (SLA), also known as resin 3D printing, is a 3D printing technology that produces parts with high resolution and accuracy, fine details and smooth surface finishes. Part of the vat photopolymerization printing family, SLA technology uses photosensitive thermoset polymers to produce custom parts. We use Formlabs materials for rapid prototyping and 3D Systems Accura materials for large-scale production.
Learn more about SLA 3D printing
SLA 3D printer capabilities
SLA 3D printing has two distinct classes: prototyping (desktop) SLA and industrial SLA. These are the key capabilities of each technology.
Maximum build sizeStandard lead timeDimensional accuracyLayer heightMinimum feature size
Prototyping (desktop) SLA145 × 145 × 175 mm (5.7 in x 5.7 in x 6.8 in)From 3 business days± 0.3% with a lower limit of ± 0.3 mm (± 0.012")50-100 μm0.2 mm
Industrial SLA500 x 500 x 500 mm (19.68 in x 19.68 in x 19.68 in)From 3 business days± 0.2% with a lower limit of ± 0.13 mm (± 0.005")50-100 μm0.2 mm
SLA 3D printed parts come in many materials
Leading companies and engineers that need to iterate quickly or get strong industrial plastic parts faster use Protolabs Network for our range of prototyping and production materials.
Industrial SLA materials
Ideal for durable functional prototypes and high precision parts with smooth surface finishes.
Accura ClearVue
Accura Xtreme White 200
Accura 25
Want to know more about SLA materials? Read our SLA materials compared article
Post-processing for SLA
Standard (no additional post-processing)
  • All support material is removed and support nibs are sanded smooth.
  • For clear resins, a polishing oil is applied.
  • Formlabs materials are cured in a Form Cure using the following settings which follow the official Formlabs “Recommended Cure” settings.
Formlabs Cure settings
ResinPost-cure timePost-cure temperature
Standard clear15 min60 °C
Standard black30 min60 °C
Standard white30 min60 °C
Standard gray30 min60 °C
Tough 200060 min70 °C
Durable1 hour60 °C
Grey pro15 min80 °C
High temp2 hours80 °C
Flexible15 min60 °C
Rigid15 min80 °C
How SLA stacks up against other 3D printing technologies
MaterialsPriceDimensional accuracyStrengthsBuild volumeLayer thicknessMin. feature size
FDM5$± 0.5% with a lower limit on ± 0.5 mmLow cost, wide range of materials500 x 500 x 500 mm (19.68" x 19.68" x 19.68")100-300μm2.0 mm (0.0787’')
Industrial FDM6$$$$± 0.3% with a lower limit of ± 0.3 mm (± 0.012")High level of repeatability, engineering grade materials406 x 355 x 406 mm (15.98” x 13.97” x 15.98")100-330μm2.0 mm (0.0787’')
Prototyping SLA8$$± 0.3% with a lower limit of ± 0.3 mm (± 0.012")Smooth surface finish, fine feature details145 × 145 × 175 mm (5.7" x 5.7" x 6.8")50-100μm0.2 mm (0.00787’')
Industrial SLA3$$$± 0.2% with a lower limit of ± 0.13 mm (± 0.005")Smooth surface finish, fine feature details, big print area500 x 500 x 500 mm (19.68" x 19.68" x 19.68")50-100μm0.2 mm (0.00787’')
SLS2$$± 0.3% with a lower limit of ± 0.3 mm (± 0.012”)Design flexibility, supports not required395 x 500 x 395 mm (15.53" x 19.68" x 15.53")100μm0.5 mm (0.0196”)
MJF2$$± 0.3% with a lower limit on ± 0.3 mm (0.012’')Design flexibility, supports not required380 x 285 x 380 mm (14.9’’ x 11.2’’ x 14.9’')80μm0.5 mm (0.0196”)
We have high standards for SLA 3D printing
We manufacture your custom parts according to strict manufacturing standards and ensure all parts and processes adhere to The Protolabs Network Standard. A thorough verification of these requirements is included in our inspection report that we ship with every order.
  • Parts are fully cured to material manufacturer specifications before shipping.
  • Hollow sections are drained of excess resin.
  • All support material is removed and support nibs must be sanded smooth.
Advantages and drawbacks of SLA 3D printing
Advantages of SLA
Advantages
  • SLA can produce parts with very high dimensional accuracy and intricate details.
  • SLA parts have a very smooth surface finish, making them ideal for visual prototypes.
  • Speciality SLA materials are available, such as clear, flexible and castable resins.
Drawbacks of SLA
Drawbacks
• SLA parts are generally brittle and not suitable for functional prototypes, though industrial SLA can produce more functional components for this stage.
• The mechanical properties and visual appearance of SLA parts will degrade over time when the parts are exposed to sunlight.
• Support structures are always required and post-processing is necessary to remove the visual marks left on the SLA part.
Design guidelines for SLA
This table summarizes the recommended and technically feasible values for the most common features of SLA 3D printed parts.
Read more about how to design for 3D printing
FeatureRecommended size
Unsupported walls1.0 mm (0.0393 in)
Supported walls0.5 mm (0.0197 in)
Minimum feature size0.2 mm (0.00787 in)
Minimum hole diameter0.5 mm (0.0197 in)
Minimum escape hole diameter4.0 mm (0.157 in)
More resources for SLA
Learn more about how SLA 3D printing works and how to design parts for this adaptive additive manufacturing technology.
Our other 3D printing processes
FDM
Fast & affordable prototyping
See our FDM services
MJF
Dimensional accuracy of ± 0.3% with a lower limit of ± 0.3 mm (± 0.012")
See our MJF services
SLS
See our SLS services
